Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Domanda Chiusa
Replaced cellular antenna but the signal is still bad?
Cellular signal isn't full 2 dots, sometimes 3 dots, in other iPhone 6 full. I changed all antenna and the problem is same.
How can I solve this problem? What the IC I must to change?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Not enough information. What antenna did you change? Did you check all RF feed points on the case?
Punteggio 2
5 Commenti:
i change all RF points on the case
da
Were there other repair history for this phone?
da
No this is a first time
da
i am buying refurbished apple device from china and reseller it but i have some of device the cellular signal is weak 3 signal dots and i changed all RF points in device and the problem isn't solved exist any ic is resbonsible for signal dots to solve this problem
da
Anything can happen in China, the condition of the device may need thorough investigation. Maybe upload some pictures of the internals? Especially around the antenna areas?
da
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 69
