Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
after removing front camera and sensor cable touch screen doesnt work
hallo,
My iPhone 5s had some problems with turning on. It gives an apple sign and then a red screen and goes back to the apple sign etc.. It gets in a loop. So i read on the internet that it had something to do with the front camera and sensor cable (the sensor should be broken). And indeed the sensor was broken. I plugged the cable out and the iPhone succeed in turning on. So my problem was solved, i thought. But after removing the front camera and sensor cable the touch screen won't work anymore. (i have also replaced the touch screen because it was broken.).
So my question is, if i plug in a new sensor and front camera cable will the touch screen be fixed? or is something else broken which will cause the failure in the touch screen?
thanks for the recommends!
Jelle
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Touch function is independent of the red screen/proxy sensor problem. This is either damage to the screen itself, poor connection, or damage to the touch connector on the board. All are common
Punteggio 1
Yes it should work if the sensor is replaced and if the screen is new :)
Punteggio 0
Aggiungi la tua risposta
jelle sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 70
