Salta al contenuto principale
Hands-free voice-activated device by Amazon powered by Alexa Voice Service. Model S04WQR.
EchoDot Not seeing Bluetooth Devices
My EchoDot has stopped seeing and connecting to my Bluetooth speaker or to my Bluetooth earphones.
Both the speaker and earphones are seen in the ALEXA app on my iPhone.
The problem started shortly after I had added the new earphones. The earphones work OK with my iPhone (play music, etc.). I do not try to join both devices at the same time. Bill D.
Questa è una buona domanda?
Punteggio 0
3 Commenti
My echo dot 4 cannot find bluetooth speakers since… yesterday????
I had some Logitech bluetooth speakers working fine until yesterday’s night. Now I cannot pair again.
da
im having same problem. Ive tried setting up the alexa on my phone again but it wont show my phone as a device to pair with on bluetooth.
da
Same here, I got a new phone and Alexa couldn’t play radio, music or find the previously connected speaker. Have cleared all settings and connections, re-installed the app, uninstalled the app from previous phone. Everything is now working apart from connecting to the speaker. Baffled!
da
Aggiungi un commento
4 Risposte
Risposta Più Utile
If echo dot stopped and unable to seeing Bluetooth speaker then see following what to do:
- Open your Alexa App on which device you are using.
- Hit Settings.
- Tap on your Echo device, Select Bluetooth and Clear all paired devices.
- Re-pair the devices, say "Pair "commands around Alexa to place the Echo in discovery mode.
- Next, head to the Bluetooth settings on your device or app in order to pair, as normal.
Punteggio 5
5 Commenti:
Alexa can't find any bluetooth speakers when i want to add new devices. She can only find them when I want to add them to the Alexa Echo. But then I can't add individual devices to different groups/rooms. They are all in the same room and all under Echo Dot.
da
didnt fix it didnt fix it didnt fix
da
Worked like a charm, lol was gonna return it till I saw this post. Thanks!
da
This hasn't fixed it for me either. I have no paired devices and now I can't connect any devise via Bluetooth to my echo dot
da
Same here. Was working fine. Suddenly stopped. Tried to re find the devices but it sees nothing at all now. This is for all 10 of my echo speakers. What did they to on the last update?
This was reported in 2022, just happened to me last week September 2023 Needs a fix urgently
Amazon tech are you listening!?
da
New permissions on android check settings, apps, permissions, Alexa, nearby devices.
Punteggio 0
I had the sane issue and after fighting with it for a while I figured out that I had ROKU app installed and they seem to be incompatible with each other. Basically you can have one or the other but if you pair them first then use them for the ROKU app then the dot cannot find them. So I uninstalled the ROKU app and they found them no problem.
Punteggio 0
In my situation near by devices was an enabled permission on the Alexa app. I had to disable that permission and re-enable it so that I could see my bluetooth devices for pairing.
Punteggio 0
1 Commento:
That did not work for me 😕
da
Aggiungi la tua risposta
wdesmith sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 49
Tutti i Tempi: 23,454
