Salta al contenuto principale
Model A1288 / 8, 16, or 32 GB capacity
451 Domande Visualizza tutte
Do I remove the plastic film from the replacement front panel?
On the back (inside surface) of the replacement front panel for the iPod Touch 2nd Generation, I have found that there is a plastic (protective?) film. The plastic film has a tab that extends underneath the front panel data cable. The tab seems to be begging to be grabbed to remove the protective film.
Do I remove this plastic film from the back of the front panel prior to installation or will that destroy the touch screen?
Thanks,
Jeff G.
Questa è una buona domanda?
Punteggio -1
1 Commento
Yes, you do want to remove it. LCD's get those as protective covers prior to being shipped. good luck
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
yes remove it. there should be a little tab, be careful not to pull off the digitizer. the plastic you are talking about should have a little die cut mark around it, am i correct?
Punteggio 0
2 Commenti:
Yup, that's the one. Silly me had that on for 6 months...
da
but I bet your screen looks brand new :) best wishes...
da
Alright, but can we actually get a real answer about the repercussions of leaving the film on vs removing it?
I always remove them, but am just curious to what would happen if you don't.
Punteggio 0
Aggiungi la tua risposta
Jeff G sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 8
Tutti i Tempi: 7,618
