Salta al contenuto principale
Modello A1136 con 30, 60, o 80 GB di hard disk con plastica frontale bianca o nera
797 Domande Visualizza tutte
Cause of cracks on the face
So I finally charged my old iPod after YEARS of not using it. It still works great, battery life is pretty sound. I don't have the old charger for it anymore, so I've been using my iPad 3rd gen charger.
I noticed growing cracks on the plastic face plate. I would assume that it was just heat or pressure from when it was in storage, but I've noticed the number and length of the cracks increase after each charge.
There doesn't appear to be any puffing when I look at the outside, and currently don't have the parts to open it up. I know I will have to replace the face. But what is causing the cracks? Is the battery just too old? I don't want this to happen again once I replace the parts.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Sounds like the battery is the issue. Its likely after being in storage for so long that is had just died.
You would need to replace the battery if you intend to do the screen aswell as nothing will fit back together with a battery that has bulged... not very safe either
Punteggio 1
4 Commenti:
Ah, wondered if that might be the case. I'll be taking a long haul flight very soon, and won't be able to get a replacement battery in time. Is it possible to just remove the battery and close up the iPod without replacing it? That way I can hopefully repair it when I get home.
da
yes removing the battery would be a good idea. Shouldn't affect the repair buy closing it up
da
Thanks! The battery was indeed puffy. I replaced it without incident!
da
Awesome! great to hear
da
Aggiungi la tua risposta
Allis02 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 201
