Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Error -1 and 56 when restoring via iTunes
Alright, I have had it with this iPhone, I tried to update via iTunes and everything was going smoothly until bam "iTunes cannot update the iPhone "iPhone" an unknown error occurred (-1) so i tried again with the same result... Then I read to take out the SIM card and do it and when I take out the SIM I get error 56. I assume at this point its a locgic board issue so I read up on it and I tried replacing the dock connector, I heated up the Baseband chip I froze it in the freezer ect. Nothing seems to work. This phone has A LOT of sentimental value to me and I really need to get it working. Is there a program out there I can use to bypass whatever is f**king up my restore? I also tried a program called 3uTools that flashes a completely new firmware and file system to the device but at around 80% it fails as well. Any help would be greatly appreciated.
Questa è una buona domanda?
Punteggio 2
1 Commento:
Any help? I'm still sitting here with a bricked iPhone, would really just like to get it restored..
da
Aggiungi un commento
1 Risposta
Hello, but what is the error code on 3uTools when you failed to flash?
And about error 56, please check this tip: http://www.3u.com/tutorial/articles/2450...
Punteggio 0
2 Commenti:
At this point, its been narrowed down to baseband. Is there any program I can use to bypass it so the restore process can finish? I dont even care about cellular data anymore I am just sick of this $30 phone from walmart.
da
You need to change the baseband.
da
Aggiungi la tua risposta
Robert Warnock sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,854
