Salta al contenuto principale
Repair guides and support for motorcycles manufactured by Suzuki Motor Corporation.
20 Domande Visualizza tutte
Gen 2 Hayabusa bogs down over 7500 RPMs
I have an 08 Suzuki Hayabusa , was out a riding went to get on it to pass a couple trucks. dropped a gear and hit the gas the bike bogs down.. I have changed the plugs thinking this was the Issue same thing still happens.... bike runs fine until i twist the throttle and brings RPMs above 7500.. its like the Secondary fuel injectors aren't firing...
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Did you find the answer my friend; i have the same issues.
Punteggio 0
2 Commenti:
Did you find what the problem was; i have the same issue
da
The issue is with your fuel regulator that is the L shape trumpet like affixed on top of your fuel unit that restrict the flow of fuel and your fuel filter
Step 1
Drain remove the tank by disconnecting all plugs and bolt attached
Step 2
Prepared a very large bucket to drain your fuel by locating the 5 Allen bolt on the based of your fuel tank.lossen it let all fuel drain
Step 3
Removed the unit be careful with the floater unit removed slowly with caution
Step 4
Unscrew the flowing unit with the 2 bolt on top set aside
Step 5
Remove the retrained white clips...be extra careful.as it plastic
Step 6 locate the L shape trumpet like shape on top
The fuel filter is the black unit the L shape fuel regulator attached d to it
Step 9 unscrew the 3 bolt of the wire folding the unit be careful fil.as they are very fragile
Step 10
Remove the fuel pump
Step 11
Clean the fuel unit
Clean for debris
Clean with carb cleaner(be careful of plastic and paint )as it can ruined it
Used Google and glovea as they can be corrosive
da
Aggiungi la tua risposta
Ula Jones sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 195
