Salta al contenuto principale
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 Domande Visualizza tutte
iMac with black screen
Hi,
My iMac makes the chime boot and the fan is running but the screen won't turn on. I conect it to an external monitor and it shows me a white screen with a question mark inside a folder and it doesn't run the OS..
Is there a solution for this issue?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Sounds like you have two problems. The first one is that it can't find a valid operating system. Fixing this one may rectify the second problem so go of it first.
Leave the external monitor plugged in for now. Boot up holding down the Option key and see if you can select the Repair Partition. If so run Disk Utilities on the drive. If nothing shows up, then boot from your original system installation disk, go to the second page of the install when the pull down menu appears and run disk utilities. If that fails you will need to replace the hard drive. Meanwhile tell us if the internal LCD lit up when booting from the DVD.
Punteggio 1
Aggiungi la tua risposta
Gio sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 376
