Is this salvageable? (decent external damage)
Hey, my old iPhone 6 got run over by a snow groomer (lol) and got pretty rekt. The internals appear to be intact except for the charger doesn't seem to be connected/functioning as I can't turn it on. Screen is a total loss, except maybe the home button? http://imgur.com/a/pbWMT
Update (07/25/2017)
Ordering a charging port to see if this will let me turn it on, or if some other internals are damaged too. I'll keep this thread updated when the charging port arrives on Friday.
Update (07/28/2017)
Found the culprit. Not going to replace yet as the case is so bent that I'm worried I would break the replacement part. Looks like the ear speaker as well as the home button are in tact as well, so it shouldn't be too expensive to replace the rest. i'm not going to replace the battery as it is unbent (except for like 3-5 degrees the last for mm) and completely fine, unless you guys think it is imperative.
Questa è una buona domanda?
1 Commento
It's not imperative if it doesn't look damaged or perforated. Maybe keep a close eye on it when you plug it in and if it overheats quickly disconnect it and dispose of it properly.
No need to mount the dock completely for a brief trial, you can leave it loose but be careful not to short any component in the process and not to move anything once is plugged in.
da arbaman
