Salta al contenuto principale
Rilasciato il 19 settembre 2014, è la versione con schermo più grande (5.5") dell'iPhone 6.
Increase memory iPhone 6 plus
Can I increase memory in my iPhone 6 Plus
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Simple answer - No!!
Punteggio 2
1 Commento:
Slightly longer answer: it can be done, but if you need to ask, you can't do it.
da
From the way I understand it ( haven't done it ) you would have to have your HDD NAND IC removed by micro soldering, have the information copied (programmed to a new larger sized HDD NAND IC and Micro Soldered back on to increase memory on iphone. Very risky though to do with a chance of bricking your phone. Or you can simply purchase larger icloud storage amount and sync your files to online for access.
Punteggio 1
It depends where you live, if you go live or go to china, this sort of thing can be done in a hour at most shops. Outside China its done less so, especially on an old phone like a 6 plus too. In the west a business would charge more than buying a new phone to do it, where as in China its not particularly expensive and can be done pretty quickly.
Punteggio 0
1 Commento:
This is basically how it's done in China. Good luck in getting anyone in the west to do it for $60 though https://youtu.be/2bGb5AOwp44
da
Aggiungi la tua risposta
Bill Hilton sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 410
