iPhone 7 Plus - Front Camera + Proximity Sensor causing malfunctioning
I did a iphone 7 plus screen replacement today & for some reason the phone starts to malfunction everytime I have the Front Camera + Prox Sensor ribbon cable attached. When attached the phone lags, the home button does not work - it shows the accessibilty icon to use as a home button, and the phone acts very weird.
At first I thought it was the replacement screen but I replaced all the part on the original screen that was cracked & I am getting the same issues.
When I disconnect ONLY the Front Camera + Prox sensor Ribbon cable, leaving the two other ribbon cables connected the phone functions perfectly fine. Home button works again, screen is 100% responsive with no lag at all. The phone works perfect.
The issues only occur when I have front camera + prox sensor connected.
I tried the original screen that was cracked & two other replacement screens. All get the same results as I just listed.
As long as the front camera + prox sensor isnt connected the phone functions perfectly, cant find a problem.
Does anyone have a solution to this? Unfortunetley I was unable to try a new proximity sensor + front camera because I did not have any on me.
Has anyone else experienced this problem?
I have searched the web but cannot find a solution.
I disconnected the battery before I removed all 3 ribbon cables, as I do with every repair.
Help would be greatly appreciated ! =D
Questa è una buona domanda?
11 Commenti
Hi.
Try to use new Flex.. new front camera flex
da Sham Kumar
I have used a new flex for this same issue. Sometimes it resolves it but not every time. Hope trying the flex works for you!
da CellularRepairEtc
We are running into this issue as well. Camera sensor and mic flex causing hardware check failure in iPhone 7 Plus, so you just see the apple logo reboot itself and repeat. When this flex is pulled, system will boot. When it attached, it does not. Even with new flex. Same issue.
da SPLYCERS SALES
We have been running into this issue at work as well with the 6 models. We believe its the aftermarket parts. Yesterday we had phones boot looping, as soon as we unplugged the prox+frontcamera flex ONLY the phone went to working completely fine. I do not know why but this is what we found so far. Will update if we find the exact solution.
da Jonathan Ruel
What did you find out with this? I am having the exact same issue.
da Wes
Mostra altri 6 commenti
