Starting issues with my 96 honda accord
Why does my vehicle have a problem starting after i drive it for a bit then when i go to start it again it has a hard time turning over
Questa è una buona domanda?
@trigger357 could be starter or battery issue. I would try the starter first. Check the ground strap to the engine and the starter. If it shows any sign of corrosion, replace it and clean the areas where it connects. Check your battery under a load and see if it is still holding a proper charge. Check on here about the explanation of "Heat Soak" which could be another issue. Let us know what you find.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 103
