have you replaced the charger recently, and where did you buy it from? also, what capacity is left in the battery currently when you press the battery indicator on the left of the mac?
I'd suggest looking into the charger as the cause of the fault, as it may not be a genuine apple one.
Its typical for dodgy replacement chargers to flicker and not function properly, they even pose fire risks, so keep an eye on it if you dont know it to be genuine apple.
I'd suspect, that if the battery was about to run out of charge, and the charger is faulty, the charger just wasn't able to charge the battery at all, so it just powered off.
If you have no LEDs on the left side of the machine (the battery indicator) and the LED is flickering, then look to test the mac with a different charger before assuming the worst.
I hope this helps.
Votato
Annulla
Punteggio
2
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
2 Commenti
The faint led is now a steady flicker and yellow
da Brad
@seekatrw - Brad, Can you give us the exact model so we can guide you the rest of the way. If you can read the S/N on the bottom cover you can plug it into here: EveryMac - Lookup then past the URL here for us to see what you have. If you can read the S/N take a look though the systems to see if you can pick it out EveryMac - MacBook Pro's
da Dan
