Salta al contenuto principale
The Motorola Droid (model number: A855) is a full keyboard touchscreen smartphone powered by Android.
33 Domande Visualizza tutte
Is it possible a replacement lcd screen will fix this problem
I have a motorola droid that got wet, I dried it out, it powered up ok screen flickered and went black. I removed battery and powered it up again, now it comes on lower bar buttons light, audible driod sound plays and screen has a glow but no display, I have disassembled and put it back together with same results, Is it likely to be ok by replacing lcd display, and if so where would I be able to purchase a replacement?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
I have no idea if a display will fix it, but you can get one here: http://www.repairsuniverse.com/droid-rep...
Punteggio 4
I repaired this same issue recently with a new lcd.
Punteggio 0
Aggiungi la tua risposta
Eric Curtiss sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,606
