Salta al contenuto principale
The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
bootlooped note 5 data pull
I found my note 5 caught in a boot loop after I woke up this morning. I've been doing everything to try and get it out but no luck. I am willing to reset my phone if I have my data though, so I was wondering if there is any software I could download which would let me pull data (such as pictures, videos, music etc) while the phone is stuck in a loop. I can power it off using recovery settings. Clearing the cache doesn't help. I'm not even sure if resetting would solve the looping issue but any info would be much appreciated, thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
You need to be able to flash a custom recovery then use the file system mtp mounting to computer then you can read the data. System and data partition should be mounted in system recovery.
You might even be able to just get the phone working again by reflash the firmware via Odin.
How to flash android firmware: http://updato.com/how-to/how-to-install-...
I usually use TWRP or clockworkmod recovery Odin flashable to do data recovery on firmware that refuses to boot without factory reset (and or firmware reflash).
Punteggio 3
4 Commenti:
So I flashed new firmware onto it and it is still looping. Should I try flashing an older version of the firmware or something? What do you suggest?
da
Then you need to flash a custom recovery so that you can use MTP mode to backup contacts and photos while in a custom recovery.
https://twrp.me/devices/samsunggalaxynot...
da
I tried flashing TWRP and It keeps failing, I also get an error on my download screen(on the phone) saying the FAP lock is on? Thanks for your help!
da
Oh.. If you have FRP lock then you are literally out of luck for data recovery. I'm afraid you will have to do a wipe data / factory reset in recovery mode and lose all your data.
If you can still get into the recovery menu and do wipe-data then do it. Otherwise reflash firmware again and wipe data / factory reset in recovery mode.
da
If you can get the phone into recovery mode, connect it to a PC with the adb tool.
The command 'adb pull <file>' can grab <files> from the phone.
Punteggio 0
3 Commenti:
Could you give me an example of how I could do this to pull music for example and which tool would be the easiest to use? Also, I know I had developer tools enabled on my phone but I'm not sure if USB debugging was enabled. Thanks!
da
Here is a great article on that.
http://www.droidviews.com/push-pull-file...
da
I followed that tutorial but I kept on getting an error that it couldn't find the phone, I might be because the phone isn't in USB debugging mode but I have no way to change that.
da
Aggiungi la tua risposta
Robel Efrem sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 19
Tutti i Tempi: 3,278
