Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Messages Crashes When Opening Message
Hi,
iPhone 6 running 10.3.2.
Issue is the messages app crashes and closes when any message is opened.
e.g., open messages > select contact > app crashes.
Any suggestions??
Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Use a program like iBackupBot to backup the messages first. Then use it to delete them all directly from your iPhone. Try it now. Problem gone ? It was one of your messages then.
Problem still there ? Then create a backup in iTunes and do a restore to factory settings (turn the iPhone off, hold the homebutton and plug it into your computer (while still holding the homebutton). Once it shows the iTunes icon on your iPhone you can let the homebutton go. iTunes will detect an iPhone in recovery mode. Choose to repair it when iTunes prompt you.
Afterwards restore your backup. Problem gone ? Then it was a software issue.
Punteggio 0
Aggiungi la tua risposta
Micah Morgan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 41
