Salta al contenuto principale
Questa è la pagina del dispositivo Samsung Galaxy J7. Il sistema operativo predefinito è Android OS v5.1.
Flickering when low light
How to solve plssss my j7 flickers when on low light how to fix help me pls should i replace the lcd or their is other things to replaced or it just needs something to be solved ?
Questa è una buona domanda?
Punteggio 5
1 Commento
my samsung J7 camera light cannot go off. steady ON
da
Aggiungi un commento
2 Risposte
Soluzione prescelta
@kobexkyrie seems to be a very common issues with this model. It is the backlight that is flickering at higher/lower power demands. Could be filter or power IC as well as the Amoled. Take a look at Flickering screen on low back light and see if some off that will work for you.
Punteggio 1
4 Commenti:
Sir what do you mean of off ?I just updated the model than it started flickering
da
@kobexkyrie of off ? I was stating that this seems to be a common issue with this model phone. Check the answers on the link in my answer to you. Click on the light blue writing :-)
da
Thanks for the help it helps me a lot to save
da
Sir unluckily it didnt work even the screen filter doesnt work also what should i do
da
I replaced with new battery and problem went away.
Punteggio 0
Aggiungi la tua risposta
Fixie sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 18
Tutti i Tempi: 17,529
