Salta al contenuto principale
Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
How to fix Hyperflashing LED Turn Signals?
I recently installed LED rear turn signal bulbs onto my 05 Grand Caravan SXT, I want to know a good way to stop the hyperflashing that happens.
Is replacing the fuse with a higher amp my best bet when it comes to this? I don't want to spend too much on this. If this is my best bet what is the fuse/ relay called?
Thank you.
Lights I used
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
No, you need to install a resistor in parallel with the led globe, as the current draw if the Led is not enought to operate the flasher relais properly.
Punteggio 1
Aggiungi la tua risposta
Scott sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 12
Tutti i Tempi: 641
