Salta al contenuto principale
La quarta generazione della Volkswagen Jetta, chiamata anche MK4 o Bora, è una berlina da famiglia della Volkswagen.
85 Domande Visualizza tutte
How do I remove the lower radiator hose?
I am replacing my radiator in my 2001 VW Jetta and cant get the lower radiator hose off. I pulled the clip off but am not sure how to pull off the hose with out braking it since its all plastic.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
See if this video points you in the right direction.
https://www.youtube.com/watch?v=3ShCTe8Y...
Punteggio 1
How do I remove parts to get to the radiator upper hoes and lower horse
Update (02/25/2018)
I went under the car and took the fan off i took off the lower hoes off but I can’t take off the upper hoes because of the clamp it’s facing up and I can get to the teeth to open it
Update (02/25/2018)
It’s the hoes from the under vw Jetta 2005
Punteggio 0
1 Commento:
Buy some LONG pliers "BFPs". Don't worry - Harbor Freight is cheap, & you'll use them all the time.
da
Aggiungi la tua risposta
Greg sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 3,450
