Salta al contenuto principale
It was a six-wheeled tank with a front-mounted blue photon beam headlamp, and a keypad on top.
Elicits unending tone when GO is pressed
I used fresh batteries on a Big Trak, early 1980's model, which had not been used in more than two decades. After I program Big Trak, I press GO and all it does is elicit an unending, loud tone. I presume it is "stuck" somewhere. Who can repair this vehicle, if it is worthwhile or possible to repair?
Questa è una buona domanda?
Punteggio 0
1 Commento:
Did you check to be sure the 9-volt is at 9 volts. Mine was at 8 and it was doing that exact thing. I am doing a once over before I put it up on e-bay, Mine is gray though. And I have the transport too.
da
Aggiungi un commento
1 Risposta
sounds like the motors are stalled.
I would work the drive wheels back and forth by hand and see if that frees it up. Also make sure ALL the batteries are fresh. These are real battery hogs.
Punteggio 0
Aggiungi la tua risposta
Gary Tameling sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 345
