Salta al contenuto principale
Lanciato il 3 marzo 2017, Nintendo Switch è un dispositivo palmare che può essere usato con la TV o in movimento.
707 Domande Visualizza tutte
Dock not working showing on tv
hello,
I seem to be getting multiple issues of the dock not working on the tv. you put it on the dock and the light in the lower left illuminates indicating it has recognized it and from what i can tell it is charging, however it does not show on the tv. i would imagine it indicated a problem with the HDMI but has anyone encountered it or know how to fix it?
Questa è una buona domanda?
Punteggio 2
3 Commenti:
Hi James,
I believe this is a common problem with the dock and may require you sending it into Nintendo for a replacement.
https://en-americas-support.nintendo.com...
da
thanks for the comment, unfortunately sending it to Nintendo is not a option
da
James, I believe @tronicsfix may be able to help but it may be a day or two before he logs on next.
da
Aggiungi un commento
1 Risposta
Try to get help from https://en-americas-support.nintendo.com..., or choose a Switch replacement like the Kacosata one.
Punteggio 0
Aggiungi la tua risposta
James sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 4,387
