Salta al contenuto principale
10.1" Android tablet released in June of 2011. Samsung GT-P7510MA
Home button not responsive after battery replacement
I replaced the battery on my 10.1 2014 tablet. Tablet booted up fine and charges, but now the Home button is unresponsive. My guess is one of the two leads that run over the battery are not fully reconnected, but I wanted to ask the question before prying the back off again.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Thank you for suggestions. I pried the back off again, one of the two leads that you unplug to remove the battery was not fully inserted. I pushed it in further and now it works fine.
Punteggio 0
Is the button on screen? If not, is it clicky or digital?
Punteggio 0
Have you tried pressing the reset hole with a pen tip at the back of the tablet? See your manual if that would be an option that would work.
Punteggio 0
Aggiungi la tua risposta
djbierman sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 937
