Salta al contenuto principale
How can I renew the graphic-card on my iMac
If I start up my iMac it works but the screen is black. The
Apple-serviceman said that the graphic-card is bad and it would be about $ 1000,-- to fix it. The computer is only five years old so I want to do it by myselfe like I repair some of my old mac´s. How does it work? Who can help me?
Regards from Austria
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
3 Risposte
Soluzione Prescelta
The GPU is integrated into the logic board. To check to see if what the tech said was true, hook it up to an external monitor via the video out port. If the external works then he was correct. Logic board repairs can be had at companies like DT&T but are rather high dollar: http://www.dttservice.com/imacg5.html
If you unit falls into this group you may have capacitor problems:
Serial Number ranges:
W8435xxxxxx – W8522xxxxxx
QP435xxxxxx – QP522xxxxxx
CK435xxxxxx – CK522xxxxxx
YD435xxxxxx – YD522xxxxxx
Punteggio 1
Thanks a lot-can you tell me where I can find this video-outport?
Punteggio 0
I found the video out port. Can I use my 21" Intel Core 2 Duo as external monitor? What do I need and how does this action work?
Punteggio 0
Aggiungi la tua risposta
Johanna Harring sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,496
