Salta al contenuto principale
Modello versione metà 2009 A1278 - EMC2326 / processore Core 2 Duo 2,26 o 2,53 GHz
745 Domande Visualizza tutte
Having problems installing OS El Capitan
Bought a Toshiba MQ01ABD100 Media drive from iFixit for my mid-2009 MacBook Pro 13" (It is the exact same model that my local MacStore installed a couple years ago.)
Using various how-to's around the internet (since the iFixit how-to is for an older OS X),
I successfully made a bootable USB drive and booted off it. Got so far as erasing the drive using Disk Utility, but when I hit 'Erase" I get the following; "Erase process has failed..." Show Details reveals: "Wiping volume data to prevent future accidental probing failed. Operation failed..." Ran First Aid, everything copacetic. Tried again, same messages.
So I guess my question is: now what?
Questa è una buona domanda?
Punteggio 0
1 Commento
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Ah! You likely need a new HD SATA cable! This series tends to have a high failure.
Here's the IFIXIT guide you'll need to follow: MacBook Pro 13" Unibody Mid 2009 Hard Drive Cable Replacement and this is the part you'll want: MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable - Apple P/N 923-0104. And yes, you want the newer part!
Immagine MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable
Prodotto
$34.99
Punteggio 1
Aggiungi la tua risposta
Robert Pillers sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 382
