Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
Is my backlight filter blown?
Well I turned off my phone to fix the selfie camera. before that everything was working fine. But I havent unplugged the battery when i take out my screen i just turn the phone off. After putting the phone back to on the screen stays black. the battery is brand new and the screen is a few months old and i dropped it a couple times my new screen comes tomorrow if it stays black anyone have any ideas what it may be and how to fix it?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Can you see the Apple logo when you are turning the device on while holding a flashlight to it? If so, the it would be your sceeen or the backlight fuse. I would double check to make sure all the connection are tight and not loose or misaligned. If that's all good, I would try a new screen then. This would be a cheaper fix. If the new screen doesn't work, then I would start to look at the motherboard.
Punteggio 0
6 Commenti:
All connections are secure. Black screen even when to into light. will try new screen tomorrow. the phone does get warm as if its on when i hold the power button
da
what could it be on the motherboard if the screen doesnt work?
da
Let me know how the new screen does for you. Have you tested the new battery you purchased to make sure it is all good?
da
the new battery worked fine i got it 5 days ago and it worked with the old screen before it stopped working. i tend to turn my phone off and remove the screen instead of taking out the battery i didnt know i had to do that. I hope its nothing serious. I mean i cant see anything though even under light the screen comes in about an hour so ill let you know
da
It was the screen :) new screen works now
da
Mostra 1 altro commento
Aggiungi la tua risposta
dj holley sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 5
Tutti i Tempi: 760
