Timing chain or timing belt?
Does a Chevrolet Starcraft 91' use timing chain og timing belt?
Questa è una buona domanda?
@erlendodegard,Erlend, Your chevy would have a timing chain. Some chains never need changed unless they exhibit chain noise(conspicuous on a cold engine and does not completely go away when engine warm). If timing check showed that the engine timing was being thrown off by the slack/wear in the chain, more then 5 degrees slack would indicate wear and time to change. Links below will supply more info. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 510
