Salta al contenuto principale
La PlayStation 3 Slim è la seconda versione della console videogame PS3 con il numero di modello originale CECH-2000. Prodotta da Sony Computer Entertainment, ha risolto molti problemi della PlayStation 3 originale (fat). È stata rilasciata il 1° settembre 2009.
PS3 display is not working
I'VE ALREADY TRIED THE HOLD DOWN that "resets" the display but doesn't work
I've tried different hdmis, and different ports the controler isn't turning on all the way and there's no yellow light. Along with it is no audio. All the answers I see are the hold down the power and reset but that is not working for me. My TV is fine it displays no signal and I've tried it onto different monitors it was working fine yesterday.
Any help
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Have you tried AV cable instead of HDMI? Tell me about lights, do you turn console on and green light is there as it should be, but no signal on tv? If so you may have GLOD. Or, maybe try to jiggle hdmi port a little see if that helps, if you get video that way, your hdmi port may be loose.
Punteggio 0
1 Commento:
Can you help identify the issue with my PS 3 console, when turned on it only displays black and white dots
da
Aggiungi la tua risposta
Maxie Masters sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 23
Tutti i Tempi: 457
