I'm having this issue with my Mac mini (late 2012) Quad-Core Intel Core i7 2,3 GHz running MacOS Catalina v10.15.7.
I have an Apple Thunderbolt display and HDMI monitor attached to it.
Changing the power saving option solves the issue but I don't want to continue using this "workaround" for my Mac mini.
Power save settings when issues occured:
Computer sleep: after 30 mins
Display sleep: 15 mins
Crash/reboot issue occurs after waking up the computer from sleep mode.
Updated Power save settings - no more issues:
Computer sleep: never
Crash/reboot issue no longer occurs after waking up the display.
Conclusion: the issue is clearly coming from the Mac mini resuming from sleep mode since it no longer happens with the updated settings that doesn't put the Mac mini to sleep mode. I don't think it has anything to do with the OS since some people are seeing this with High Sierra but I'm using Catalina.
Current workaround power save setting is not my preferred one since it keeps the mac awake and is consuming power all the time.
I will probably be doing some more tests in the coming days/weeks.
Votato
Annulla
Punteggio
0
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
4 Commenti
I might add that it will also fail to boot when I attempt to cold boot. It gets stuck in a loop and the only way to make it boot at all is to go into recover mode, run first aid on the drive, then restart. It will run until I leave it idle for anything more than maybe ten minutes.
da Ryan
I also have this problem its only manifest itself in the last 6-8 weeks or so
on my maxed out Macmini mid 2011 [5,2] i7 2.7 GHz
L2 Cache (per Core): 256 KB
L3 Cache: 4 MB
Memory: 16 GB
Boot ROM Version: 135.0.0.0.0
SMC Version (system): 1.75f0
I cannot identify what change may have triggered these rebooting cycles, apart from some incremental updates from Apple, as I've been running High Sierra on this machine for a long time now without other problems.
I did have one of my two 2TB Seagate FireCuda go bad a few months ago - maxing out its bad sectors allocation - so I replaced it with a Samsung EVO SSD 1TB - which I was used first as the primary boot drive - but when this rebooting behaviour began - subsequently trying to isolate causes I have created a Fusion Drive out of the 1TB SSD and the other Seagate 2TB HD - with a fresh install of 10.13.6
Now reboots often on return from sleep and boots 2-3 times on fresh start from shutdown before eventually reaching log-in screen
da timjomartin
I have an observation - and a theory {system as described above on Nov 20)- if I boot holding option key - my APSF formatted Fusion drive appears as two separate drives if I choose the first it boots normally ... if I choose the second it goes into a number 2/3 cycles of booting before finally coming up booting successfully in the main first volume ...
My conjecture/theory is that the second drive ikon represents the 'root' level APFS container 'volume' that perhaps contains elements of a recovery partition but reboots in attempts to pass the boot process to the main partition ...
Is it possible that returning from sleep the awakened software is making a similar redirection that results in a reboot rather than awakening in pre-sleep status ... ??
It is possible that this problem first appeared when I began to use APFS formatted SSD ... and has persisted through the creation of a Fusion drive ... ??
da timjomartin
Update - so far so good - I read a suggestion on another thread - about deleting cache files ... so I used Parallels Toolbox's component 'Clean Drive' and allowed it to clean up my Log Files and Cache Files ... and 'touch wood' so far I have had all 'clean' single boot and restart sequences sequences so far ...
da timjomartin
