Salta al contenuto principale
The OnePlus X smartphone was released in November 2015 by OnePlus. It is identifiable by model number E1005
Can I remove the vibration motor from my phone?
Hi, my phone's vibration motor is rusty around the 2 wires and vibrates continuously as soon as the phone is plugged. I am wondering if I could simply remove it? Does the phone work without the vibration motor, may I simply cut both wires?
The phone is a Oneplus X.
thanks
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If there are only two wires connecting the motor an now PCB board on the motor, then it should work. Can you solder of the motor? That would be better in case there would be a problem you could then solder the motor back on, but it should be no problem. Hope I helped you.
Punteggio 2
1 Commento:
Thanks, I removed the vibration motor and it works.
da
Aggiungi la tua risposta
Paul-Emile Veuve sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,251
