Salta al contenuto principale
This is the device page for the Samsung Galaxy J7. The OS that comes stock to the device is Android OS v5.1.
170 Domande Visualizza tutte
Why my phone is not charging?
I was browsing Internet, then suddenly my phone start to heat & it was increasing. Then I turn it off & after a few time connect it to charger in off mode. I saw in display that remaining 34% of charge. After 2 hours when I came to unplugged the charger I was shocked to saw that it still showing Battery 34%. Suddenly the percentage start to decreasing although it was connecting to charger. After a short time the battery percentage gone to 0% & the phone completely shut down. Now it's not charging or getting on? What can I do Now & what is the main reason behind it? Is tha a major problem? How can I fix my mobile phone as before?
Questa è una buona domanda?
Punteggio 3
1 Commento
Hi. Im using my Samsung galaxy j7 prime. It was working properly bt suddenly it was not charging i thought charger problem but i changed many chargers not working. But if i connect in system or a laptop its charging. Wat issue is this? Can anyone help
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@amitsharmin by your description it sounds like a bad battery. Start with a new one and let us know how it progresses. There is always a possibility that it is your charger, your cable or bad charging circuitry on the circuit board. Always start with the easy things like a new battery.
Punteggio 3
Aggiungi la tua risposta
Amit sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 9
Tutti i Tempi: 4,974
