Salta al contenuto principale
Annunciato il 9 settembre 2014, questo dispositivo rappresenta la prima incursione di Apple nel mondo dell'elettronica indossabile. I manuali di riparazione iFixit sono applicabili all'Apple Watch (acciaio) e Apple Watch Sport (alluminio).
210 Domande Visualizza tutte
Has anyone successfully replaced the Display Flex Cable?
I know it requires board level soldering. I saw the first two videos of a three part series that seemed pretty good. But alas, I'm not sure the gentleman ever finished the repair, because there isn't a third and final video. It looks relatively straightforward from the point where he left off.
I picked up the watch for a very minimal investment and the cable is inexpensive. So I figured what have I really got to lose?
I'm just curious if anyone has successfully completed this repair? Do you have any advice, if so? Or is there a guide somewhere that I haven't found yet?
Thanks!
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
3 Risposte
Risposta Più Utile
hey! Apple has been using this connection style for some time now to save thickness.
I have successfully replaced this type of connection in ipads for their Charge ports, and ipod 5th gen as well,
I have not done this specific replacement, but i beleive the process to be very similar on the watch, just on a smaller scale. if you plan to do this, i suggest a 10X + Microscope. it does require some practice, as it is a specialized skillset.
Punteggio 2
2 Commenti:
Hmm, I don't have one of those. I haven't soldered anything this small before. Mostly I've done stained glass and simple repairs on wiring to battery compartments. I have worked with other tiny things before. (Assembling and doing better quality painting on 28mm miniatures, etc.) I hate to just give up on the watch, but I don't want to ruin it because I was too stubborn either.
I have another Series 1 (the one for repairs is a Series 0) that is in excellent shape but iCloud locked. I guess I could use that one for practice?
da
that would be a good idea. the iron tips used in stained glass are usually much larger than the ones used for microsoldering. however, i dont know how fine of work you do with the glass. best of luck, and if you need anything let me know.
da
I am also trying to figure out if it replaceable. I have fixed 3 series 1 38 mm apple watches before and they were simple. The one i was fixing yesterday was very difficult and i got very angry when it did not work. I opened up again and the flex cable was torn just a bit. Please link me to a video that shows how to fix it. I cant find anything! (I dont have much experience with small scale repairs like apple watches)
Punteggio 0
https://youtu.be/xrJJa0oU8FA
Punteggio 0
Aggiungi la tua risposta
Katherine sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 2,220
