Salta al contenuto principale
Announced - 2014, November The Samsung Galaxy Core Prime (G360, G361) is powered by 1.3GHz quad-core processor, and it comes with 1GB of RAM. The phone packs 8GB of internal storage that can be expanded up to 64GB via a microSD card.
67 Domande Visualizza tutte
Are similar samsung batteries interchangeable?
So, my phone model is an SM-S820L. I'm having trouble finding batteries for it, but have found a lot for model SM-G360P. It looks pretty similar, and I'm wondering if I can use the battery for that model in my phone. (Both of these are Galaxy Core Primes, I think, but SM-S820L seems to be a somewhat "rare" model, as a lot of places don't seem to know what it is...)
Also, do I need a SIM card to use the phone, or can I just work off WiFi?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Soluzione Prescelta
You only need the SIM card installed to send text messages and make calls + cellular data via a phone number.
Otherwise you can just use the phone as is on Wi-Fi just you can't do the above until you have a sim card installed.
While they look similar most of the time the size of the battery is different and will not fit. You better look for the same model battery.
Edit: After researching both those batteries. It looks like they both use the same battery and it's the same battery capacity. You should be able to use those batteries vice-versa as they are basically the same.
Punteggio 4
It'll work on wifi only, just like a tablet. I've been doing that for over a year with my phone.
Yes, the batteries are cross compatible. It needs to be three things: same voltage (nearly always 3.7v) same capacity, and same physical size.
Hope this helps!
Punteggio 3
1 Commento:
I just buy a new phone when the one I'm using starts to fall apart because it is like a chain reaction and i just like having a new phone
da
Do all samsung tab batteries are same or they differ by model
Punteggio 0
Aggiungi la tua risposta
Josh Bennett sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 51
Tutti i Tempi: 10,193
