Salta al contenuto principale
Processore quad core Intel Core i7 da 2,2 GHz (3,4 GHz con Turbo boost), 2,5 GHz (fino a 3,7 GHz con Turbo boost) o 2,8 GHz (fino a 4,0 GHz con Turbo boost) con 6 MB di cache L3 condivisa.
774 Domande Visualizza tutte
My display is showing only lines and nothing else
My MacBook began showing green vertical lines on various areas of the display. now the display black with pink lines across it. However, when i connect it to an external display. The image is fine and no lines are shown. Is it a GPU problem or is it the display?
I tried resetting the PRAM and the SMC.. it made no difference.
Questa è una buona domanda?
Punteggio 1
4 Commenti
When you move the screen same result?
da
Yes, when I move the screen it's the same result. I tried pressing the corners or even twisting a little but it remained the same
da
My laptop is having same problem help me out plzzz
da
@rkabra4u hi, check for dents on the screen lid, most likely there's a dent somewhere that was pinching on the LCD/LED screen damaging it. If there are no dents, try replacing the cable that connects the screen to the laptop. However, if the lid has a dent, you'll most likely have to replace the screen.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Before you replace the LCD, try just reseating the cables. If it still does not work, try just slapping the back of the LCD a few times, it may move it back into place. Otherwise it would be a defective LCD. When it started, was there any recent drops, spills?
Punteggio 2
1 Commento:
I tried reseating the cables but that didn't help. Gonna try slapping the back and see if it helps.
There were no spills, however it did fall of my car seat while driving and hit the floor. It was in a hard case and in my bag. This happened like 1yr ago.
da
Aggiungi la tua risposta
jiovany sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 257
