Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Microphone not working when on whatsapp call
How can I solve this problem.
When I'm in a whatsapp call and I put the loudspeaker on, people won't here me same as video whatsapp call.
I try on facetime and it does work even a voice call or video call.
I think its something wrong with the mic or the app.
Questa è una buona domanda?
Punteggio 12
22 Commenti
Speakerphone mic not working with watsapp , viber and skype - works fine with GSM calls and Facetime
I have re-installed the apps , reset the settings and also restored the entire phone but no use.
So frustrating.
da
my phone as well, very frustrating! so what did you do now?
da
Having same issue with iphone 5 ios 10.3.3 on only whatsapp calls , caller won't hear me with loudspear turned on,
All other voice/video calls with loudspeaker works fine tryed almost ever thing in vain.
Waiting for jailbreak to install previous version of whatsapp which might resolve it.
da
i am also having the same issue.
da
What do I do also having dat issue
da
Mostra altri 17 commenti
Aggiungi un commento
19 Risposte
Risposta Più Utile
The loudspeaker issue was resolved when I did the following:
  • open whatsapp
  • settings
  • Data and storage use
  • select ‘wifi and cellular’
however it did not solve the video call problem! Still can’t be heard but i can hear fine…
Punteggio 5
1 Commento:
This worked for me
da
Its not what’s up issue, it’s apple. It just stopped working for several apps. Most likely an update changed the choice of mic( sounds like a monopoly to use facetime) and it doesnt work or works some times. Another thing is wether you replaced your screen recently. It could well be the flat connectors that is damaged. Its worth checking, swaping the connectors. At last resort, if you change your screen, you will have new connectors and that should solve your problem! Hope it works for you, leave a message if it did.
Punteggio 2
8 Commenti:
I'm having the same issue after a replacement to screen on iPhone SE, but everything is working fine in normal phone calls, but stops working on calls from/to whatsapp
Did you figure out a solution for this?
da
Im having same problems it works with normal calls or FaceTime but don’t work with WhatsApp if I put on loud speaker so frustrating
da
Been having audio problems with my IPhone 8 whatsapp. When on a call, people can’t hear me!!! I’ve tried to fix it but nothing works!!
da
@hildaavello you need to start your own question, or scroll through all the device answers until you find a solution. This is lost in a question several years old
da
My microphone is working fine but during video call on WhatsApp and Imo I can hear voice of caller from phone not from my headset
da
Mostra altri 3 commenti
I have Iphone 6 that is running on IOS 11.1.2 which is the latest version.
I have WhatsApp 2.17.81 version which also seems to be the latest.
The problem is that for Audio calls, the moment i switch on the speaker, my mic gets off and hence the callled party cannot hear me. It works well if my speaker is off though.
On Video calls, since speaker is on by default, my mic doesn't work.
I emailed it to whatsapp support team and this is what they have to say:
Sorry for the inconvenience. We are aware of the issue and we are working on fixing it in a future update of WhatsApp. Unfortunately, we can't comment on any future release dates at this time.
If you have any other questions or concerns, please feel free to contact us. We would be happy to help!
Sylvester
WhatsApp Support Team"
Punteggio 1
2 Commenti:
Oh well that’s helpful.
da
It’s 2021 and I still have the same problem on an iPhone 6 as above since 2018 don’t u guys have a fix yet
da
This symptom occurs to me after I send the iPhone 6s for battery replacement. That is the hint. After trying many other software solution I resort to opening the device myself. I bought the iPhone screwdriver set from online and open the iPhone. I re-seat the front camera connector and screw everything back on. The microphone works like charm with Whatsapp now.
Punteggio 1
Unfortunately there is no fix to it. But just use your iPhone headset that has built in microphone on it. That works perfectly.
Punteggio 1
The first thing you should do is to ensure the system condition is great since you make voice/video call via internet. When utilizing WIFI, make sure that you are within the range of the router. If the sign is missing, try restarting your router or modem, unplug it, then plug it back in.
Punteggio 0
I had a problem like this in my iphone 6s. Front mic didn’t work or had low sound in all video calling (whatsapp, facetime, google duo etc). After reinstalling all apps or system factory formatting it didn’t fixed.
After that I changed the battery with unscrewing screen, facetime has fixed and had great sound, but whatsapp has normal or low sound. I think my problem has fixed.
Punteggio 0
In my 6s, I had the same problem. Facetime was totally fine while whatsapp calls have no audio on the other side of the call. The issue turned out to be the front facing microphone (the one next to the earphone, on the top, facing forward, is not visible from outside) malfunction. In order to fix that, I had replaced the front facing camera assembly which includes this microphone. It was not a hard fix. After the fix, both facetime and whatsapp calls are fine.
Punteggio 0
If you can only hear people on whatsapp with your microphone on, and then talk with your microphone off, the top microphone on your iphone needs replacing. Siri will also not work by voice command if this microphone is no longer working. I got it replaced for $60 and now whatsapp and siri work normally.
Punteggio 0
I just rebooted iphone xs max and it restored contacts in dialler and also microphone was added back for whatsapp.
Punteggio 0
no fix, just skip WhatsApp and use other apps, simple as that
Punteggio 0
Hi, I had this very same problem with Whatsapp calls on my IPhone 7: I could not place calls nor record any audio message. I could also not place nor receive any calls using the normal mobile line / GSM.
I tried to switch the phone on and off several times but no luck. I also tried to go into settings —> Whatsapp —> microphone and then turn off and on the mike, but also this did not work.
It worked instead when I did the following: STEP 1: Settings —> Whatsapp —> microphone and turn the microphone off. STEP 2 (with the mike under Whatsapp still off..): turn off the phone. STEP 3: Switch on the phone STEP 4: Settings —> Whatsapp —> microphone and turn the microphone on. I did it and it worked…cheers
Punteggio 0
iPhone has two mic
try to speak on the second one next to camera lens.
Punteggio 0
https://youtu.be/0Js-LzdXo9E see and fix micrphone broo
Punteggio 0
change front camera and sensor flex it will work
Expert Gsm
Punteggio 0
Whenever a person call me on WhatsApp call the person can hear me
Punteggio 0
1 Commento:
then your microphone is working fine. You don't need to reinstall WhatsApp.
source:
https://bit.ly/3G5AfHc
da
I have an iPhone 6 . Speaker not working on WhatsApp anyone got a fix yet
Punteggio 0
Update (04/12/23)
Punteggio 0
Hello, try restarting your phone if you haven’t already. If that try deleting the app and reinstalling it. The last option would be to see a repair store. Preferably not the Apple store, they charge extreme amounts for the smallest things. Try going to a repair store.
Punteggio 0
Aggiungi la tua risposta
sfeaugas sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 92
Tutti i Tempi: 171,215
