Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Difference "No SIM" and "Searching" problem
Hello
Lately I'm seeing a lot of iPhones with SIM problems, either with "searching" or "no SIM" appearing in the top left corner of the screen.
I wonder what the difference between the two is.
As far as I know "No SIM" means that literally no SIM card is detected in the tray. What does the other one mean and how do they differ.
Thanks in advance guys ! :)
Questa è una buona domanda?
Punteggio 2
1 Commento
I f iphone is searching then there is a hardware issue and you need to solder the logic board.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Unless simcard reader is damaged on its own, as far as I experienced it really makes no difference, no service or searching or no sim are just different states the phone gets stuck on. They're different faces of the same coin, but they usually point all to a baseband fault.
Punteggio 2
Aggiungi la tua risposta
Didier Daniel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 618
