Why has the sound stopped?
the sound has stopped all the functions are working but no sound
Questa è una buona domanda?
msthang332001, Make sure the Line In Switch is in the off position if not using the Auxiliary Input, make sure the line-in switch, located on the back of the system near the auxiliary cable, is in the off position. It may be a bad volume switch/connection, bad speakers/connection, possible fuse blown for internal amp. if equipped or could be a faulty amp. The guide 1st link below will help get you inside the device to check/test components. If under warranty have repaired/replaced/refund under the warranty. Last link is Crosley support page. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 12
Tutti i Tempi: 264
