Salta al contenuto principale
Rilasciato il 19 settembre 2014, è la versione con schermo più grande (5.5") dell'iPhone 6.
1525 Domande Visualizza tutte
error 9 and 14, related to screen fix?
I changed my screen on iphone 6 plus, because it cracked once.
Updated to IOS 10 (like 4 months ago)
since then continuously get error 9, 14, and 2009
tried to fix at store , they swapped ic flash power but still iphone crashes
may the error be related to (probably non genuine) screen replacement?
Can't update or restore at all...
Update (06/12/2017)
Hi ben, thanks for the more detailed answer... so what to do , should i attempt to fix it myself, and loosen up the screws?
thanks...
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
It's probably long screw damage from putting too long screws or overtightening the screw holes on the board.
The screw holes in particular are the 3 out of the 5 lower screw holes for the metal cover that goes over the screen connectors on the logic board.
This is hard to spot without a microscope in the screw holes.
Punteggio 2
2 Commenti:
so what to do? should i loosen the screws? thanks for the answer....
da
Loosening the screws won't help. If this is the case you will need to take it to someone that does micro soldering to fix the long screw damage on the board.
da
Risposta Più Utile
Board issue, you need to find someone with board repair skills.
Punteggio 2
Aggiungi la tua risposta
Stephan Georgi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 353
