Salta al contenuto principale
È la terza generazione dell console di gioco Xbox della Microsoft. Questa edizione è stata rilasciata il 22 novembre 2013.
E101- What is the cause and how to fix
Bought an Xbox one on ebay advertised as having E101/E102. Displays E102, then after either the offline update or the factory reset USB it displays E101. Upon restart it goes back to E102. I've tried both of the tools, but every time it says something went wrong. The first time I tried the the update tool it hung at 5%, so I shut it down and retried. Then it would immediately say something went wrong. When I try the factory reset option, it reboots and then says something went wrong. It's still got the warranty sticker, and I plan to resell it, so opening it up to reformat the hard drive isn't prefered. Also, should I have too, is reformatting the HDD all that's necessary to installing the OS? Does it install it from the internet? Thanks.
Questa è una buona domanda?
Punteggio 2
1 Commento
@tronicsfix help, please!
King of Consoles :-)
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
It's that the update partition on your hard drive is corrupted. You can use the Xbox diagnostics tool (I don't remember the exact name, it can be found on Xbox's page, though), or fix the update partition by disassembling the Xbox and plugging the hard drive into a pc and following a guide on se7ensins. Your last options would be to send it in to Microsoft or sell it.
Hope this helped!
Punteggio 1
4 Commenti:
I know I can fix it by de-corupting the HDD (I did that on my own with E200) but it still has a warranty sticker, so I'd prefer not to open it. Is there any way to do it externaly?
da
Thanks. Turned out my HDD is all messed up.
da
I find nicht se7ensins guide. Link?
Thanks ;)
da
Link please for the se7ensins guide
da
Aggiungi la tua risposta
George A. sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 69
Tutti i Tempi: 16,479
