Salta al contenuto principale
iPhone con schermo da 4" introdotto nel marzo 2016 con specifiche hardware simili a quelle dell'6s. Disponibile in Argento, Oro, Grigio siderale, Oro rosa con 16 o 64 GB. Modelli A1662 e A1723.
My phone is not charging and is stuck on 1%
my iphone se is not charging and it stays stuck at 1% battery with the charger pluged.
when i remove the charger it stays on for 20 seconds, but it's moving verry verry slow, it s like the battery not giving enough power.. after the phone shuts off, is trying to turn on by himself, apearing the apple logo and disapearing until probably drains all the remaining battery..
when i plug the charge, the apple logo apears and disapears couple of times and after 2-3 minutes the operating system starts normaly with the 1% battery(probably the battery is charging a little bit).
there are times when the phone starts with 100% battery but when i remove the charger, the same problem, it s shuting down after 20 seconds
the battery is new, but it s an aftermarket.. could it be something else beside the battery?
Questa è una buona domanda?
Punteggio 8
3 Commenti
I’m having sorta the same problem, but mine is stuck at one percent but dosent die when it’s off the charger, I plug it in and it still says 1% no matter how long I leave it, but it also dosent die off the charger
da
I just recently bought a new charger because my other one was not working and it would stay on one percent but say its charging. I have tried moving it to different outlets and the same thing would happen. Now it's dead and wont come on. It was dead last night so I went to sleep and it got on 100 percent the night before. But the battery will just not go up. Can someone please explain what's wrong?
da
It's the battery and it can be killed if you often use your phone while charging .
da
Aggiungi un commento
5 Risposte
Soluzione Prescelta
The most likely culprit is the battery. There are many cheap and poor quality batteries on the market. I would certainly try a new one or preferably, a known-good battery.
If that doesn't solve your problem, then you likely have a defective charge circuit on the logic board. It could be as simple as the battery gas gauge line having a blown or dislodged filter or it could be at the Tristar/Tigris chip level. Those are not DIY repairs and you should seek out an experienced micro-solderer if you don't have the tools or experience.
Punteggio 10
8 Commenti:
Wow! Nice Job on 25k! Head over to meta for the celebration!
You forgot to mention who has the best batteries around: iPhone SE (1st Gen) Battery
da
@pccheese what this celebration?
da
@theimedic check out ifixit meta at https://meta.ifixit.com It's for site related stuff. I finally got the post up. I thought I posted it when I didn't.
da
Mostra altri 3 commenti
Ny phone has a new battery, bought it at Walmart store. It hasn't even been a day long and my phone only charges 1% ,what's wrong whith is phones.
Punteggio 2
2 Commenti:
What battery? Is there a place on my IPad for a battery . If so, what kind of battery.
da
Is there a battery or just my plug in
da
Or could possibly need a new usb cable
Punteggio 0
So when i charge my phone its just staying at 80% idk if its just my phone or its the battery it was going up to 100% till yesterday.
Punteggio 0
1 Commento:
yes mine too
da
I had this problem with my SE. It is due to a microscopic coil (inductor) that sits beside the battery being broken off when prying the battery out. You need microsoldering tools to put it back on.
Punteggio 0
Aggiungi la tua risposta
Bilbureanu Robert sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 49
Ultimi 30 Giorni: 181
Tutti i Tempi: 86,679
