Annoying car honk sound
Does anyone have an annoying double honk like from a car, coming out of their phone? For the life of me I cannot find which app is doing this and it is !#^&^$^ me off.
Questa è una buona domanda?
Hi, i managed to put an end to the annoying car honk sound coming from my phone.
The cause: I had recently installed an app called Park + which was synced with the RFID on both my cars. Everytime each car entered or exited our apartment complex, the RFID was automatically scanned.
The notification setting on the app was programmed to sound me an alert whenever these scans happened, and the default sound was the car honk sound.
Solution: I deselected the alert and since then the sound has stopped.
If you are facing the issue due to same reason, hopefully the above solution works like it did for me.
Thank you so much! Mine was the exact same thing!! I just couldn't figure out the reason before 😅 Thank you!
Start here:
Go to Settings --> Sounds and Notifications.
Make sure none are set to your honk.
If this doesn't work,
Go to Settings --> Applications
Check running Applications.
Disable one by one until you figure out which one is honking.
The problem is that the honk only occurs rarely, so it would take forever and a day to track down which app is causing it by disabling. In addition, the honk is not a standard notification sound, nor did I install such a sound bite. Virus checker finds nothing.
I believe the phone telling you you have text.
Ultime 24 Ore: 2
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 52
Tutti i Tempi: 2,611
1 Commento
Did you find out the reason? I've been having the same problem and it's really annoying :/
da Tushar Sindhu
