Salta al contenuto principale
Guide di riparazione, manuali e aiuto per la risoluzione dei problemi per PlayStation 3 Slim. Ottieni tutto il necessario per riparare da solo il tuo PlayStation 3 Slim.
Help opening PSU cover?
I've opened up the PS3 and I want to open up the PSU unit, but I don't know how to get the plastic cover off. I've taken the screw out the bottom and I've pushed the latches at the back so the back opens up a bit, but it stays shut from the front, are there other thing I have to do?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione prescelta
Step 13 of our PS3 Slim teardown denotes the PS3 slim power supply. I think there are several retaining clips in front preventing the power supply cover from opening. Other than that, it should come right off.
Punteggio 1
Had the same issue; in my case there were no visible tabs to push back. After tinkering and pensively forcing it open, I realized that the tabs were hidden internally. Out comes the screwdriver, and after popping the 3 tabs on the vent side, the back vent is one whole tab that holds the 2 pieces together. That takes a while to open.
Hope it helps.
Punteggio 1
Aggiungi la tua risposta
Ryan sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 15
Ultimi 30 giorni: 85
Tutti i Tempi: 12,022
