Salta al contenuto principale
Support and repair information for Beats Solo3 headphones.
63 Domande Visualizza tutte
Fixing no sound in one speaker on blueooth
I am having issues issues with the right side of my Beats solo3 wireless headphones. On bluetooth no audio comes out from the right side and the right side will only work if i jiggle the left side. Both sides work fine when using the aux cable for wired setup. What could be the issue?
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
5 Risposte
Risposta Più Utile
Plug in your auxiliary cord to your headphones to device, play some music, and if it works like that than take the auxiliary cord back out, turn on blutooth and both will start working again.
Punteggio 2
8 Commenti:
I did it and it didn’t work. Twice. Help plz!!!!
da
It didn,t work for me either
da
Didn't work for me either
da
Didn’t work for me either.
da
I know this is old, but i just tried this and it worked
da
Mostra altri 3 commenti
I have the same problem too
Punteggio 2
If anyone is still having this problem I was able to fix my Beats Solo 3 Wireless issue with no sound on one speaker on bluetooth after I followed the instructions on this video: https://www.youtube.com/watch?v=kypDTpO_...
Hope this helps.
Punteggio 0
1 Commento:
This doesn’t help at all.
da
It could be a loose or damaged connection, would have to disassemble and inspect to determine the correct issue.
First try a reset etc.
Punteggio 0
Bruh I don't know what to tell
Punteggio 0
1 Commento:
Yeah you might need new ones
da
Aggiungi la tua risposta
MrSnowyOwl sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 34
Ultimi 30 Giorni: 97
Tutti i Tempi: 45,586
