Salta al contenuto principale
LG's flagship smartphone, with a unique slide-out battery and detachable I/O module supporting multiple hardware expansion options. Released in April 2016.
20 Domande Visualizza tutte
Local bands not supported. New housing will fix?
I have a Sprint LS 992, which doesn't connect to data in Australia; even after adding APN. I'm trying to connect to Vodafone's network.
Will I be able to switch out the housing to the Australian back and use those antennas in Australia?
Will this solve the problem? Are there any issues with this solution?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
First of all, have you tried configuring the APN network settings for your carrier / service provider that you are using in Australia?
Try this first if you haven't already because overseas phones generally tend not to autoconfigure APN network automatically for sim cards that aren't from the same country the phone came in which results in no mobile data connection and MMS (Multi-Media-Messages [Image attachment / Video attachment over SMS text messages]).
Basically what you will need to do is google '<Carrier Name> (e.g optus) apn network settings'
Then setup the APN profiles as specified from the first few websites (e.g optus.com.au of course).
A guide on how to setup APN settings (You can't use these settings of course as they are for T-Mobile sim card which is U.S):
https://support.t-mobile.com/docs/DOC-30...
If you want you can tell me the service provider you want to use and I will provide instructions for that service provider on how to setup the APN settings properly for Mobile Data and MMS.
Punteggio 2
2 Commenti:
Hi Ben,
Thank you for the suggestion. I've added an APN; this hasn't helped.
da
Try this: https://forum.xda-developers.com/sprint-...
Also note that to use MMS using the method I linked you requires using a 3rd party app instead of the stock messaging app if you want multimedia messages to work.
da
Aggiungi la tua risposta
Chonye Morozow sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 117
