Salta al contenuto principale
Rilasciato il 19 settembre 2014, è la versione con schermo più grande (5.5") dell'iPhone 6.
1525 Domande Visualizza tutte
Wifi toggle grayed, time changing, bluetooth spinning
So as of lately I've been having a string of different events happen with my iPhone. The wifi toggle stopped working and is just grayed out, the Bluetooth wheel keeps spinning as if it's searching. Phone goes off at night and when it is turned back on time changes. When I tried to set it to automatic time the wheel is spinning as well. My phone is updated to the latest IOS, I've reset the network, heated up my phone (for the wifi) hard reset the phone. Could it have been that this was jail broken at a point in time and it's affecting the phone ? It was bought used after 2 months of use.
Any help would be appreciated. Thank you!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
A faulty wifi/bluetooth chip can cause problems with time setting, they're interconnected. Sounds like you should find someone who can replace that chip for you. I doubt any jailbreak could cause hardware failures as such.
Punteggio 1
Aggiungi la tua risposta
Karina sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 494
