Salta al contenuto principale
Rilasciato il 19 settembre 2014, è la versione con schermo più grande (5.5") dell'iPhone 6.
1525 Domande Visualizza tutte
sometimes restarts after touch ic.
hey people, i did an meson ic repair, but the phone restarts sometimes. also the visual disapears sometimes, when putting the lightning cable in for example. and sometimes when i start the phone there is no backlight and visual. and sometimes its bootlooping. what could this be? do i have to search around the dock connector? or is this something where the backlight filtes are?
hope somebody can help me.
Questa è una buona domanda?
Punteggio 0
1 Commento
* its not bootlooping anymore. after the first meson job i started the phone and touch worked. then suddenly te phone restarts and no touch. after the the second meson touch was back, but the boot problem is still there. the was not too much heat on the board.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
My suspicion would be too much heat, even if you don't think it to be the case. The edge of the CPU and you also have a row of passives that affect the camera, backlight etc directly opposite Meson. You may also have shorted some pins underneath Meson.
At this point you could try pulling Meson again, inspect the M1 pad (for your touch issues) and try booting the phone without it. If it still bootloops, then your problem is elsewhere.
Punteggio 1
1 Commento:
thans for your answer! i will try, but touch works perfectly so meson should be fine right?
da
Aggiungi la tua risposta
thieske sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 811
