Salta al contenuto principale
The Venue 8 is a midrange Android tablet, released by Dell in 2013.
Where is the HDD located on a Venue 8
Disassembling a Venue 8 5120 for Recycling and I wanted to remove the HDD to destroy it and I cannot seem to figure out what part is the
HDD
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Tablets usually have an "HDD" soldered on to the board. Unfortunately, unless you identify the storage chips on the PCB, there isn't a physical "HDD." It is rare to find a replaceable/upgradable storage drive on a tablet.
More appropriately, it might as well be called an SSD, but still.
If you can boot it up and trigger a system reset so that it clears the onboard storage and returns to factory default, you shouldn't need to worry about it. Otherwise, take a stab at random chips and see which ones hold the data.
Punteggio 1
This image is from dell venue 8 pro.. but the chip is an BGA-153 on ailexpress. have not hear if anyone has upgrade it or not..
Punteggio 0
Aggiungi la tua risposta
Denom Krall sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,740
