Salta al contenuto principale
6th generation Android smartphone designed by Google and manufactured by Huawei. Released October 2015.
63 Domande Visualizza tutte
Why is my phone stuck on Google, it seem to be froze
My phone seems to be stuck on Google , I have reset it and nothing seems to change
Questa è una buona domanda?
Punteggio 0
1 Commento:
Jennifer, were you able to solve it? I have encountered the same problem.
da
Aggiungi un commento
3 Risposte
It seems that you've encountered bootloop of death, you have to RMA your device. Or you might've encountered a problem that I've also encountered when using Android O. If that's the case then downgrade your system to 7.1.2 on Android Beta page, then factory reset by turning off your phone, pressing Power + Volume Down and wait few seconds until you'll load into bootloader, then using volume buttons select "Recovery Mode" and press power button, then hold power button and click volume up and you'll see a screen with device info and a menu, navigate to "Wipe data/factory reset" using volume buttons and press power button, select yes, and then select reboot system now, it should be fixed if you had the problem that I had.
Punteggio 0
https://www.thecustomdroid.com/fix-nexus...
http://myhexaville.com/2017/09/25/nexus-...
Punteggio 0
It may help you out
https://techzy.net/nexus-6p-bootloop-fix...
Punteggio 0
Aggiungi la tua risposta
Jennifer Cooper sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 265
