Salta al contenuto principale
Il top di gamma Huawei nel 2016. Basato su un case unibody, ha una doppia fotocamera posteriore sviluppata in collaborazione con Leica. Può avere 32 o 64 GB di memoria interna e sei diverse finiture esterne. I numeri di modello sono EVA-L29, EVA-L19 ed EVA-L09.
The fingerprint sensor is not working
Heyie please help
My Huawei p9 eva-L19 fingerprint scanner not working.... In the settings it's showing "you can't use your fingerprint to"
Plss tell me what to do .my phone running on Android os 7.0
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
4 Risposte
Soluzione Prescelta
Did you do a unoffical flash / flash to different firmware doing a manual method when updating to Android Nougat 7.0?
Or did you do update using the updater that came with the phone?
Note that the phone requires at least a 4-digit pin passcode (Android pattern won't work) to use the fingerprint sensor.
Punteggio 3
hello
i would like to ask how to remove the password in my fingerprint management because i dont know the exact password this lady used and im thousand miles away from them, Please help me so i can update my fingerprint.
Thank you.
Punteggio 0
2 Commenti:
My Y6 2019 Huawei phone fingerprint sensor is not working and it's also not showing settings for fingerprint. Please what am I going to do?
da
da
Punteggio 0
5 Tips to Fix For When Your Fingerprint Sensor Isn’t Working
Update Your Phone Software
Recalibrate Your Fingerprint
Restart Your Phone
Get Support
Replacing Your Sensor Yourself
Regards,
Rachel Gomez
Punteggio 0
Aggiungi la tua risposta
Christopher Banton sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 11,480
