Salta al contenuto principale
The Nintendo GameCube Controller DOL-003. Released November 2001, compatible with Nintendo GameCube, Nintendo Wii, Nintendo Wii U, and Nintendo Switch. Repair for this device is straightforward and requires only common tools.
GameCube Controller not responding got it two days ago
Just need some help fixing my controller it seems to not work anywhere but my other one works fine.
Questa è una buona domanda?
Punteggio 2
1 Commento:
Where did you get it from?
Did it ever work?
Does the cable or the controller itself seem to have damage?
da
Aggiungi un commento
2 Risposte
Are any of the wires inside the wire casing broken? This tends to happen to second-hand controllers, especially if the wires where wrapped around the controller to tight during storage.
Punteggio 0
something you can do to trouble shoot the wire is take a multimeter and your controller open up the controller hold one of the pins on the gcc port
make sure you are only in contact with one pin on the multimeter then on the circut board test each socket that the cable plugs into there should be 6 while testing each port you should hear 1 beep per gcc port socket if you hear to then you have some wires crossed if you dont hear 1 then you have a weak connection or cut cable
Punteggio 0
Aggiungi la tua risposta
Jaskaran Singh sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 572
