Are these 2 MOSFETS the same value?
MOSFET A = 5:26
MOSFET B = 6:33
MOSFET A is from an 820-00165-A
MOSFET B is from 820-00875- 1
Any help would be greatly appreciated.
Questa è una buona domanda?
MOSFET A = 5:26
MOSFET B = 6:33
No way to know 100% due to unavailability of schematics on the 2016 models, but they should be the same component. The last bit of writing on chips or MOSFETs are usually batch number related; it's the first line or 2 which are important
That seems right to me, thank you for affirming my assumption, always nice to have a second set of eyes to look at something. Much appreciated!!!
Yep, they are both the same. You can source them at Digikey.
https://www.digikey.com/products/en/disc...
Here is the data sheet.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 650
5 Commenti
Which model is it? Board number or screen size and year? Where exactly are they located, have you got a picture with a larger look of the board?
da Reece
da Forza Vale
@reecee - The upper is from a Early 2015 MacBook Air 13″
The lower image is from a Late 2016 MacBook Pro 13" Function Keys system. Checkout this image: Logic bd look just below the RAM (orange) slightly to the right.
Not sure which system he's trying to fix here.
da Dan
If trying to fix the 2016 MacBook Pro, I don't have access to donor board or schematic. My assumption is that they are the same but wanted to clarify;
da Forza Vale
Top one is Q7155 SI7137DP SO-8 Vishay manufactures those and you can get the datasheet from http://www.vishay.com/docs/69063/si7137d...
da oldturkey03
